OBDLink MX WiFi: A Wireless Gateway to Vehicle OBD Networks
Geplaatst: 04 feb 2014, 10:12
door chc
Code: Selecteer alles
Zal dit apparaatje ook op onze 3L werken? Ik zie er niet expliciet OBD2 bijstaan, wat op onze 3L zit toch? :D
OBDLink MX WiFi is a fun little gadget that lets your phone talk to your car, in real time. It's easy for anyone to use, and it works on iOS, Android and Windows platforms. Use it with a variety of highly-rated apps that enable you to connect with your car like never before. OBDLink MX WiFi is like a swiss army knife for your car!
Don’t let its modest looks fool you: it is absolutely the awesomest device of its kind, for the following reasons:
  • -Dozens of compatible apps, and more added all the time!
    -Intelligent sleep mode: plug it in, and forget about it -- it won't drain your car's battery
    -Lightning-fast performance, MX WiFi runs circles around the competition
    -Easy setup. Yes, even a caveman can do it.
    -Uncompromising quality, backed by the best warranty in the industry
    -Firmware updates. Update MX WiFi with newly developed features.
OBDLink MX WiFi's functionality is limited only by the imagination of the programmers that write the apps. Apps that exist on the market today, can be used to:
  • -Improve your gas mileage
    -Remote start your car (on select vehicles)
    -Create a digital dashboard or a heads-up display
    -Buy a used car with confidence
    -Lock/unlock doors (on select vehicles)
    -Clear the ‘Check Engine’ light, and investigate its cause
    -Make your phone go “Vroom! Vroom!”, in sync with the gas pedal
    -Impress your friends, family, and significant others
Specifications
  • -Wireless module: 802.11b/g
    -Encryption: AES128
    -Current consumption: 100 mA (normal), 0-10 mA (sleep)
    -Dimensions: 1.97 x 1.77 x 0.91 inches (51 x 45 x 23 mm)
    -Weight: 1.2 oz (33 g)
    -Operating Voltage: 8-18V DC
    -Operating Temperature: -4º to 131º F (-20º to 55º C)
    -Operating Humidity: 10 to 85% (non-condensing)
Supported OBD protocols
  • -ISO 15765-4 (CAN)
    -ISO 14230-4 (Keyword Protocol 2000)
    -ISO 9141-2 (Asian, European, Chrysler vehicles)
    -SAE J1850 VPW (GM vehicles)
    -SAE J1850 PWM (Ford vehicles)
    -SAE J2411 (GMLAN, Single Wire CAN)
    -Ford MSC (Medium Speed CAN)
Bron: https://www.kickstarter.com/projects/obdsol/obdlink-mx-wifi-a-wireless-gateway-to-vehicle-obd
Re: OBDLink MX WiFi: A Wireless Gateway to Vehicle OBD Netwo
Geplaatst: 04 feb 2014, 11:14
door Joch3m
ik heb een soortgelijke dongle maar dan op bluetooth icm torq op mijn smartfoon, werkt prima.
Geplaatst: 04 feb 2014, 13:15
door Willemvee
Of het werkt hangt van het bouwjaar van je 3L af denk ik.
Geplaatst: 04 feb 2014, 13:27
door Kanerr
Jep, oudere types met oude ecu's zal niet werken.
Geplaatst: 04 feb 2014, 13:37
door chc
D.w.z. bouwjaar < 2001 waarbij het niet gaat werken, toch? Is het trouwens aan de aansluiting te zien, welke OBD versie je hebt? Heb al "gepledged", ben benieuwd! :pray:
Geplaatst: 04 feb 2014, 14:35
door reichbus
De oude 3L' s hebben het KW 1281 protocol en die staat niet in dat lijstje. Helaas.
Geplaatst: 04 feb 2014, 14:40
door chc
Welk protocol gebruiken de nieuwere dan?
Geplaatst: 04 feb 2014, 14:44
door reichbus
ISO 9141-2 (motorcode AYZ). Als ik de gegevens van jouw auto goed zie dan moet dat kunnen.
