Code: Selecteer alles
Zal dit apparaatje ook op onze 3L werken? Ik zie er niet expliciet OBD2 bijstaan, wat op onze 3L zit toch? :DDon’t let its modest looks fool you: it is absolutely the awesomest device of its kind, for the following reasons:
- -Dozens of compatible apps, and more added all the time!
-Intelligent sleep mode: plug it in, and forget about it -- it won't drain your car's battery
-Lightning-fast performance, MX WiFi runs circles around the competition
-Easy setup. Yes, even a caveman can do it.
-Uncompromising quality, backed by the best warranty in the industry
-Firmware updates. Update MX WiFi with newly developed features.
- -Improve your gas mileage
-Remote start your car (on select vehicles)
-Create a digital dashboard or a heads-up display
-Buy a used car with confidence
-Lock/unlock doors (on select vehicles)
-Clear the ‘Check Engine’ light, and investigate its cause
-Make your phone go “Vroom! Vroom!”, in sync with the gas pedal
-Impress your friends, family, and significant others
- -Wireless module: 802.11b/g
-Encryption: AES128
-Current consumption: 100 mA (normal), 0-10 mA (sleep)
-Dimensions: 1.97 x 1.77 x 0.91 inches (51 x 45 x 23 mm)
-Weight: 1.2 oz (33 g)
-Operating Voltage: 8-18V DC
-Operating Temperature: -4º to 131º F (-20º to 55º C)
-Operating Humidity: 10 to 85% (non-condensing)
Supported OBD protocols
- -ISO 15765-4 (CAN)
-ISO 14230-4 (Keyword Protocol 2000)
-ISO 9141-2 (Asian, European, Chrysler vehicles)
-SAE J1850 VPW (GM vehicles)
-SAE J1850 PWM (Ford vehicles)
-SAE J2411 (GMLAN, Single Wire CAN)
-Ford MSC (Medium Speed CAN)
